[8365] MQO file format character encoding / Nick
対応済み [質問] 返信
What character encoding is used for the whole MQO file?
Does the new CodePage chunk match the character coding for the whole MQO file or just the "names" and "filenames" that appear?
Does version 1.2 mean whole MQO file is utf-8 including names?
2019-09-18 13:43
途中の2件のメッセージを表示
[8368] Re: MQO file format character encoding / 管理者
CodePage can be defined at the header only once, and all strings in the file must be matched with the encoding. Utf-8 should be used for multi languages.
2019-09-20 15:51
