[8389]
mirror axis field default value
Nick
[質問]
Sample model cat.mqo has joined mirror (2) but has no mirror axis set in file. Does this mean mirror axis defaults to X axis if it is not in file?
2019-10-12 20:45
[8390]
Re: mirror axis field default value
X axis is a default axis for mirroring. In very old versions, mirroring is applied to the X axis only.
2019-10-16 12:58
