[8556] Unexplained Crash / Mollis
[不具合報告] 返信
Version 4.7.2 (64bit) of Metasequoia
Operations that done before the error occurs:
I was using the UV edit function and adjusting the rotation of the plane tool. I was going back and forth applying it and rotating it when it inexplicably closed the program. Once reopening the program no crash report was seen and no prompt to recover lost data was issued.
Windows 10 Home, 64bit Operating System.
Manufacturer and model of your PC/GPU:
2019 Microsoft Corp.
Intel Core i7-7700 CPU with 8.00 GB of RAM
2020-03-01 16:40
[8557] Re: Unexplained Crash / 管理者
Did the crash only happen once? or does it happen often?
2020-03-02 15:08
