[8815] Cursor Size / Tom
[要望] 返信
OS: WIN 10
Metaseq: 4.7.4d (64 bit)
Monitor Resolution: 3840 x 2160
With a high resolution the command cursors within Metasequoia are very small and hard to see. I tried changing the cursor_drag.txt from 15,15 to 30,30 thinking that would make them bigger. But no luck. I may have to redraw them all bigger.
Is the cursor size adjustable? I have not found it. Thank You
2020-09-03 07:03
[8817] Re: Cursor Size / 管理者
The command cursors is not adjustable, but you can use the normal arrow cursor. Please open [Configuration] and switch [Figure of cursor] in the Mouse category to [Arrow]
2020-09-03 09:38
