Which version of DoGA CGA System do you use?
2021-07-15 20:53
L3, the las one that Team DoGA released.
2021-07-15 22:29
When you export to DOGA-L series, the model must be assigned materials that are loaded from genie.atr.
The function of loading .atr files is obsolete in the latest version, so please use Ver4.6.9 or older versions.
And, the function to export parts to DOGA-L series was designed DOGA-L1 and L2 which didn't have a modeling function. Since the structure under the common folder is the same between DOGA-L1/L2 and L3, you can export to DOGA-L3, but it is not optimized. Therefore, please edit the part within DOGA-L3 if necessary.
DOGA-L3 is now very old software, so we no longer know the details.
2021-07-17 14:07
One correction. It is only the output that is obsolete, so it can be imported in the latest version.
In any case, detailed support is no longer available.
Please make sure that the material name in the .suf file, the definision in .atr file, and texture location are appropriate.
2021-07-17 14:23
