[9118]
edge inset
Tyler Kingsbury
[要望,edge inset tool ]
can you add a edge inset tool like in zbrush or 3ds max as it would speed up the modeling workflow
2021-08-30 17:35
[9119]
Re: edge inset
What is the 'edge inset'?
I searched by the keyword, but I couldn't find about it.
2021-08-30 21:38
[9121]
Re: edge inset
Tyler Kingsbury
found a video that talks about it
https://youtu.be/la4ai5JKpPw
2021-08-31 00:26
途中の2件のメッセージを表示
[9122]
Re: edge inset
I seem [Extrude] command and [Extrude faces] menu with the appropriate angle are similar to the features in the video.
2021-08-31 12:19
