Hello, I've noticed that some of the materials aren't shown in the material asset library when using the [RenderMan] command. Mainly, it shows only materials that have only this at the start of the "asset" file:
"RenderManAsset": {
"usedNodeTypes": [
"PxrSurface",
"shadingEngine"
But if there are more nodes in the "usedNodeTypes" then the asset library doesn't show the material as available, for example if it has:
"RenderManAsset": {
"usedNodeTypes": [
"PxrTexture",
"PxrManifold2D",
"PxrLayer",
"shadingEngine",
"PxrBump",
"PxrLayerSurface",
"PxrLayerMixer"
Then the material gets ignored.
Are there plans to support multi-node materials with the [RenderMan] command? Because most of the example materials use that and can't be used in Metasequoia.
2022-01-29 16:20
