>the Edit panel rotate use to say 90° not 4 Deg
2022-04-24 06:59
>ok it works correctly on my other PC and laptop, I can not find a setting to change it stopped working maybe a year ago
2022-04-25 07:05
When the rotation button in Edit Panel is dragged, it rotates by 15 degrees if the Shift key is pressed, or by any angle if not pressed.
2022-04-25 13:59
>When the rotation button in Edit Panel is dragged, it rotates by 15 degrees if the Shift key is pressed, or by any angle if not pressed.Did you look at my pictures?????? the problem is still there.
2022-06-12 02:41
When I check the operation, nothing is wrong and it displays correctly. I have no idea why it is like your case.
2022-06-14 12:32
