[9385] EDIT PANEL___Degree indicator / Tom Evers
対応済み [不具合報告] 返信
the Edit panel rotate use to say 90° not 4
2022-04-23 22:47
途中の6件のメッセージを表示
[9458] Re: EDIT PANEL___Degree indicator / 管理者
I found the cause for this problem. It seems that the angle notation becomes incorrect depending on the [Display unit].
We will fix this problem in the next release.
2022-06-17 13:10
