[9407]
The Select, Rect and Rope command wont work
Lia
[不具合報告]
I wanted to model something but the select, rect and rope command wont work. I cant select verticles.
How do I fix this?
Please help me.
2022-05-16 07:26
[9408]
Re: The Select, Rect and Rope command wont work
Perhaps one of these two methods will solve your problem.
* Push the space key to release the [Sel Lock]
* Unlock the object on the object panel
2022-05-16 12:07
[9410]
Lia
It sadly still wont work.
2022-05-17 00:22
途中の2件のメッセージを表示
[9411]
Lia
Ok i figured it out but ty!
2022-05-17 02:35
>Perhaps one of these two methods will solve your problem. >* Push the space key to release the [Sel Lock] >* Unlock the object on the object panel
