[9440] Request for feature / Colin Buley
[要望] 返信
Will you or can you ever save files with textures?
I regularly use meta for editing files from outfit studio and have to export as OBJ and after editing in meta re-inport back but have no textures. I work around it but it would be great if the option was supported in meta!
Regards Colin
2022-06-09 01:33
途中の2件のメッセージを表示
[9443] Re: Request for feature / Colin Buley
Outfit Studio has its textures in a seperate pathed folder to its meshes so gathering those textures when exporting in some way would be time consuming at best. Could you suggest a simpler easier to understand option which may be included in a future release of meta?
Regards Colin
2022-06-09 15:05
