When I create a cylinder with R=40mm, H=2mm, and then another cylinder R=2mm, H=2mm, then perform a Boolean subtract smaller radius from bigger radius, the end result is a failure. When the radius of the smaller cylinder is 10mm instead of 2mm it works as expected. Interesting!
2022-07-08 14:16
