[9473] Boolean issues with small cylinders. / Martin
[不具合報告,Boolean - weird issue] 返信
When I create a cylinder with R=40mm, H=2mm, and then another cylinder R=2mm, H=2mm, then perform a Boolean subtract smaller radius from bigger radius, the end result is a failure. When the radius of the smaller cylinder is 10mm instead of 2mm it works as expected. Interesting!
2022-07-08 14:16
途中の8件のメッセージを表示
[9482] Re: Boolean issues with small cylinders. / Martin
>I still cannot confirm your problem. Can you send me an image or mqoz file that I can see under what circumstances it happens? Please send an email to support@tetraface.co.jp
Sounds good, email sent!
2022-07-11 13:04
