[9516] Focus point in RenderMan / Alexander
対応済み [質問,Focus point in RenderMan] 返信
I can't exactly set the focus point in RenderMan, please tell me how to exactly set the focus point when rendering through RenderMan? Is it possible to add a function to accurately set the focus point?
2022-08-01 00:25
[9519] Re: Focus point in RenderMan / 管理者
When [Depth of field] is enabled and [Synchronize view] is active, the focus point is at the same position as the center of rotation of the view.
Therefore, the [Attribute] > [Fit to view] menu can be used to specify the exact position.
2022-08-04 13:59
