[9571] Direct x or .x importer / Moggy
対応不要 [質問] 返信
Will you be implementing a .x importer?
Regards,
Moggy
2022-11-03 17:21
途中の9件のメッセージを表示
[9650] Re: Direct x or .x importer / Moggy
>>>the .x format maybe old but its still supported by some people in the industry.
>>I don't know what industry you're in, but I believe it is risky in every respect to continue to use an industrial system that relies on old technology and does not support modern formats.
>>However, if you must do so, as already mentioned, an external converter can solve the problem right now. Have you considered that option?
No matter , I found a number of free solutions that don’t involve online conversions! It’s a shame there is no .x importer for your software. Life find a way!
2023-01-18 00:51
