[9659]
bridge attach form
Riton
[質問]
hello,
I would like to link 2 cube and cylinder objects together. I read that the Bridge function exists but I can't find it.
2023-02-06 19:40
[9660]
Re: bridge attach form
Riton
Through perseverance, I found how to do it. You have to use the 'Hole' tool
2023-02-06 21:23
[9661]
[Help] has a search function, so please make good use of it.
2023-02-07 15:48
>Through perseverance, I found how to do it. You have to use the 'Hole' tool >
