[9704] cant use metaQ anymore crashes / metaSeq Script editor no longer works
[アナウンス,py script non works] 返信
none of the py scripts arent working anymore.
no error it just crashes whole metaq
any script i run it crashes, even from folder scripts not working
cant use naymore :S
2023-02-17 15:14
[9707] Re: cant use metaQ anymore crashes / 管理者
Have you solved the problem yet?
While it is rare for a Python script to terminate abnormally when used, it is possible for a problem to occur, e.g., by using the wrong function call.
We can't offer any advice without knowing what script you are running, but please let us know if you know what the offending trigger is.
2023-02-20 10:56
