[9725]
USD File support
Neptrone
[要望]
Hello can you add export import for USD fie ? it's a modern 3D file format and it's open-source too.
https://www.openusd.org/release/index.html
2023-03-28 17:06
[9726]
Re: USD File support
For what purpose do you need USD file?
I know that it is used by major video production companies, but I do not know much about its actual use.
2023-03-28 19:42
>Hello can you add export import for USD fie ? it's a modern 3D file format and it's open-source too. > >https://www.openusd.org/release/index.html
