[9764] Render Error / Chupples
[不具合報告] 返信
I have a textured mqo file which gives me an error when I try to open it. I can open it with Meta3 but not the current version...
Metasequoia 4 Ver4.8.5b (64bit) is running.
Windows version : Windows 10 x64 22H2  Build:19045
Number of CPU : 20
Physical memory : 16128 MB
Direct3D11 Driver: NVIDIA GeForce RTX 3060 Laptop GPU
    DeviceID: 9504
    SubsysID: 292822277
    Revision: 161
    FeatureLevel: 11.4
Error occurred in the rendering.(D3D11)
Access violation in module Metaseq.exe at address 00007FF622E04971, for writing 0000000000000000
0x00007FF622E04971 Metaseq.exe: `RenderObjectFlat'::`50'::RenderObjectFlatProcess::Process + 3985 bytes
0x00007FFEE662F750 dbghelp.dll: SymGetModuleBase + 720 bytes
0x00007FFEE662F624 dbghelp.dll: SymGetModuleBase + 420 bytes
0x00007FFEE662E26D dbghelp.dll: StackWalkEx + 1277 bytes
0x00007FFEE662E0C6 dbghelp.dll: StackWalkEx + 854 bytes
0x00007FFEE662DFE5 dbghelp.dll: StackWalkEx + 629 bytes
0x00007FFEE662DEC6 dbghelp.dll: StackWalkEx + 342 bytes
2023-06-27 03:53
[9765] Re: Render Error / 管理者
Can you send the mqo file to us?
If you can, please contact support via email.
2023-06-27 17:29
