[9810] Cant open file because of the Blinn shader type / Lee Phelipe
対応済み [不具合報告,shader/file] 返信
hello, long time metaseq user here, in recent updates i've noticed the blinn shader was removed from the software, well the issue is that i have a bunch of old files where i used the blinn shader quite a lot and now some cant be opened quite right, theres this file in particular that is quite big and it straight up crashes the program and i cant go to the materials tab and replace the blinn shader with anthing else, what should i do?
2023-11-04 14:27
途中の2件のメッセージを表示
[9813] Re: Cant open file because of the Blinn shader type / Lee Phelipe
thanks, it worked
2023-11-05 04:26
