[10387] Rotate around a specific axis / Chris
[質問] 返信
I amd trying to figure out if there is a way to rotate/array whatever you want to call it around a no normal axis. So I have a model which is on an angle. It needs some repair so I am remodeling some parts. Once I've modeled the part I need to circular array them around the axis of the part that is on the angle. Is there a way to do it?
Thanks
2025-08-23 06:44
