[2950] Mr / Stuart Bassett
対応済み [質問] 返信
Hi. Just wondered how to use the Lathe option.
I looked through the help file but can not find any instructions for it.
Thank you.
Regards
Stuart.
2013-01-25 12:45
[2952] Re: Mr / 管理者
Please create lines by the [Create] command after enabling the Lathe option.
2013-01-25 17:36
[2953] Re: Re: Mr / Stuart Bassett
That's the thing, how do I enable Lathe option, there's nothing to click or enable.
2013-01-25 20:05
[2954] Re: Re: Re: Mr / airflamesred
prop button on top of object panel. Lathe is on the right. Select axis and segments. Voila!
2013-01-26 00:37
[2955] Re: Re: Re: Re: Mr / Stuart
Thank you very much. Got it to work.
Kind regards
Stuart.
2013-01-26 04:23
[2956] Re: Re: Re: Re: Re: Mr / airflamesred
My pleasure. Mind the double sided polys.
2013-01-26 08:08
