[3225] beta 4 - bug report / Mark
[不具合報告] 返信
Thank you for the opportunity to test.
Grid options not available in edit options - can not remove the XZ grid.
Right click 'register to tool panel' not working on Anguwrap - I think because plug in?
Edge extrude with shift only according to screen = I think world coords is correct.
Edge loop selection seems erratic when reaching a pole.
2013-08-04 02:44
[3231] Re: beta 4 - bug report / まじかる☆しげぽん
Hello, a mark
ZX grid can be made undisplayed if ZX plane is turned OFF from the Disp button of each view.
>管理者さん
日本語環境でも、メニューの各プラグインの右クリックからのツールパネル登録ができないようです。
2013-08-05 01:59
[3258] Re: Re: beta 4 - bug report / Mark
Ah! now I find these options.
2013-08-05 23:19
[3346] Re: beta 4 - bug report / 管理者
Yes, and now all buttons in the panel can be registered to tool panel with beta2.
I don't know which operation you indicate. Please more details.
2013-08-13 20:13
[3347] Re: Re: beta 4 - bug report / Mark
Edge extrude as predefined with the shortcut 'H'
2013-08-13 20:22
[3348] Re: Re: Re: beta 4 - bug report / 管理者
I see. I misunderstood it's the extrude command.
Only dragging operation can move on the two directions, not three axes. Therefore, it moves on the screen coordinate. And it can move along X, Y or Z axis on the three orthogonal views.
2013-08-13 20:29
[3351] Re: Re: Re: Re: beta 4 - bug report / Mark
Maybe confusion here?
I refer to 'pull face' as defined. If selecting in perspective, the extrusion is constrained to screen. It is impossible to make a selection in orthagonal - catch 22!
2013-08-13 21:04
