[4788] shading smooth angle / shading smooth angle
[質問] 返信
What is working mechanism of smooth shading angle in the obj property pannel?
2014-08-28 19:03
[4790] Re: shading smooth angle / 管理者
Put a cube by [Primitive] command, and set 89 or 91 degrees to the smooth angle.
You can find the difference.
2014-08-28 20:09
[4791] Re: Re: shading smooth angle / shading smooth angle
Thanks for your reply, I can understand 'smooth shading' option is like enable the glShadeModel(GL_SMOOTH).I just want to know how the smooth angle works in the shading, is it work in normal calculation or something else?
2014-08-29 10:59
[4792] Re: Re: Re: shading smooth angle / 管理者
Smooth angle affects the normal calculation.
Plug-in SDK contains a source code for the normal calculation. Please refer MQ3DLib.cpp if you understand C++ program.
2014-08-29 15:14
[4793] Re: Re: Re: Re: shading smooth angle / shading smooth angle
Thanks, that really helps a lot. But do you have MQ3DLib.cpp with english annotation?
2014-08-29 19:43
[4805] Re: Re: Re: Re: Re: shading smooth angle / 管理者
We will release a new sdk for the next update; Ver4.3.
And it will contain English annotation for the normal calculation.
Please wait a moment.
2014-09-05 11:28
