Hello... Mizuno... Many thanks for your software.
I buy Meta...4EX version. Now I tested trial version.
I found one problem.
This is Korea and used Win10.
I opened old my 3d files to make meta...3.
And I found blank in object list of object panel.
Maybe Korean not supported.
So... I try make new... But same error...
If I type Korea... out put is blank(box).
Pls inform for solve it.
2016-05-14 13:55
[6549] Re: about Object name / 管理者
Are boxes displayed? I guess you use the default font; Segoe UI.
You can change the font setting in the [File > Configuration] menu. You should select Malgun Gothic.
2016-05-17 11:23
[6550] Re: about Object name / Yang Jin Guk
Don't solve it... Do you have other ways?
2016-05-17 18:30
