[6765] Mr. / Marc Wilmet
対応済み [不具合報告, ] 返信
Hi,
I just downloaded the latest version 4.5.7 (64-bit).
I'm using the licensed standard version for Windows.
When I import a mesh in Wavefront OBJ format that contains textures/Materials, these ones are not properly loaded because the drive's letters are not included in the file's name.
Example : Material3994, the Reference is :  /textures_MD/Silk01.jpg
But it would be :
E:/textures_MD/Silk01.jpg
I consider that Metasequoia 4 is one of the most user-friendly application for modeling. Its interface is superb.
Thank you very much.
2016-11-20 06:39
[6766] Re: Mr. / 管理者
>Hi,
>But it would be :
This is a correct behavior on the Windows and UNIX. The leading slash means that the file is placed under the root folder.
The software used to export wrote a wrong path. If you want to load the texture file from a relative path, the path must be written like as texture_MD/Silk01.jpg or ./texture_MD/Silk01.jpg in the .obj file.
2016-11-21 14:00
[6767] Re: Mr. / Marc Wilmet
>>Hi,
>>But it would be :
2016-11-22 05:20
[6768] Re: Mr. / Marc Wilmet
>>>Hi,
>>>But it would be :
Hi,
I'm sorry for the duplicated post. Please could you delete it? (I had some difficulties to understand how this BBS Editor is working.)
Thank you for your fast reply.
2016-11-22 05:38
[6769] Re: Mr. / Marc Wilmet
Again, I'm sorry.
In my previous comment, please read this :
In the Material's Reference, I find this : /textures_MD/silk01.jpg
2016-11-22 05:44
[6770] My apologies, there is no bug. / M W
You're absolutely right ! There is no bug.
My sincere apologies for my mistake.
The solution was to simply mention the drive letter as absolute path in the configuration.
2016-11-28 06:30
[6771] Re: My apologies, there is no bug. / 管理者
Thanks for your report. Please continue to feel free to ask here if you have any questions or problems.
2016-11-29 12:12
