[7248] bone dll fail to load / gaetan diotte
対応済み [不具合報告,bone.dll fail to load] 返信
Metasequoia 4 Ver4.6.1 (64bit) is running.
Windows version : 10.0  Build:15063  (x64)
Number of CPU : 4
Physical memory : 7641 MB
C:\Program Files\tetraface\Metasequoia4\Plugins\Command\bone.dll : Failed to get a version of plug-in.
C:\Program Files\tetraface\Metasequoia4\Plugins\Command\bone.dll : Failed to load.
    Unsupported version.
Direct3D11 Driver: AMD Radeon HD 6530D
    DeviceID: 38474
    SubsysID: 102567973
    Revision: 0
    FeatureLevel: 11.0
2017-09-19 07:12
[7249] Re: bone dll fail to load / 管理者
Is the bone.dll for 64bit version of Metasequoia?
32bit or 64bit between Metasequoia and a plugin must be matched.
You should install 32bit version of Metasequoia to use the plugin.
2017-09-19 10:39
[7253] Re: bone dll fail to load / gaetan diotte
bone.dll file in Meta 64 plugin folder is date 2013.07.15 Where to find correct bone.dll for meta 64? Do I delete program and re-install?
arigato!
2017-09-20 22:51
[7254] Re: bone dll fail to load / 管理者
I don't know bone.dll for 64-bit. All old plugins before Metasequoia 4 are for 32-bit only.
You must delete the bone.dll, install 32-bit Metasequoia, and put the bone.dll in the 'Plugins/Command' folder in 32-bit Metasequoia.
Otherwise, you should use a standard bone command in Metasequoia 4.
2017-09-21 09:59
