[7561] Stuck in mirror mode / Andrew Harris
[不具合報告] 返信
Went to use mirror mode in drop down menu and I can’t get it to stop. Even if I uninstall and reinstall... I’m using a MacBook Pro os is X.
2018-03-17 00:01
[7562] Re: Stuck in mirror mode / 管理者
Which drop down menu do you mean? Right-click on the Object Panel?
And, which version os do you use? All OSs on the mac are X.
2018-03-19 14:32
[7565] Re: Stuck in mirror mode / Andrew Harris
I use Sierra ver 10.12.6
The drop drown menu I’m referring to is at the top of the program under selected. It’s the one under extrude faces and above move faces to a new object. For now, I an making sure I stay away from th4 center point to make sure I don’t mashed together.
2018-03-20 03:04
[7566] Re: Stuck in mirror mode / Andrew Harris
>The drop drown menu I’m referring to is at the top of the program under selected. It’s the one under extrude faces and above move faces to a new object. For now, I an making sure I stay away from th4 center point to make sure I don’t mashed together. I checked the object panel and I have mirror checked as none.
2018-03-20 03:12
[7567] Re: Stuck in mirror mode / Andrew Harris
Good news.... I figured out how to stop my issue being stuck in mirror mode. The button sym wass active. I turned it off and it stopped.
2018-03-20 12:42
