[9566] Selection doesn't work / Konstantin
対応済み [不具合報告] 返信
New installation.
Comman>Edit>Select doesn't work
Select All doesn't work
Windows 10 64 bit
2022-10-23 16:50
[9567] Re: Selection doesn't work / 管理者
The operation you have performed may have caused it to be unselected. Please check to see if any of the following apply.
* [Sel lock] is active by pressing space key.
* The object is locked in the [Object Panel].
* [CObj] in the [Edit Option] is active.
2022-10-24 10:03
[9568] Re: Selection doesn't work / Konstantin
Thanks!
2022-10-24 18:35
