[9674] FILE> EDIT> attribute> selected> object Delete Lines / Delete LINES
対応不要 [要望,help! ] 返信
import MQSystem
doc = MQSystem.getDocument()
objnum = doc.numObject
for oi in range(0, objnum):
    obj = doc.object[oi]
    if obj is None:
        continue
    if obj.name == "obj":
        obj.select = 1
        break
hmm i cant find to delete Lines in there :/  so script editor deletes lines for me ! doing script but cant find that one :S
2023-02-13 13:38
[9679] Re: FILE> EDIT> attribute> selected> object Delete Lines / 管理者
Find each face that has two vertices. The pseudo code is thus.
if obj.face[i].numVertex == 2:
   obj.deleteFace(i)
2023-02-14 10:58
[9680] Re: FILE> EDIT> attribute> selected> object Delete Lines / cant mirror in code dsnt let me select mirrored fa
>   obj.deleteFace(i)
import MQSystem
    if obj is None:
        continue
           obj.deleteFace(i)
error
Name not found globally.
name 'i' is not defined
2023-02-14 11:15
[9681] Re: FILE> EDIT> attribute> selected> object Delete Lines / 管理者
Don't you understand what 'pseudo code' means?
It doesn't work as is, so you need to make your own improvements to incorporate it.
See more standard samples included in the Script folder.
2023-02-14 14:04
