import MQSystem
doc = MQSystem.getDocument()
objects = [None, None]
objnum = doc.numObject
for oi in range(0, objnum):
obj = doc.object[oi]
if obj is None:
continue
if obj.name == "obj1":
objects[0] = obj
for obj in objects:
if obj is None:
continue
obj.mirrorType = 1 # Separate at center
obj.mirrorAxisX = 1 # Disable X axis mirroring
obj.mirrorAxisY = 1 # Enable Y axis mirroring
obj.mirrorAxisZ = 0 # Disable Z axis mirroring
obj.mirrorAxisLocal = 1 # Use global coordinate
after i run the code i can select only one mesh how to apply or flip cloned object to x axis horizntaly ?
2023-02-14 09:30
[9685] Re: flip horzitanly :S / d4rt
You need to freeze the object to be able to edit the mirrored mesh:
obj.freeze(2)
2023-02-15 05:00
[9687] Re: flip horzitanly :S / no error in code.
>obj.freeze(2)
did try but nohting. lol :S
2023-02-15 09:48
[9690] Re: flip horzitanly :S / d4rt
Just so I understand you want a script to mirror an object along the X axis like you do through Menu > Selected > Mirror (ZX, Local coordinate) and also keep the original mesh?
2023-02-15 21:23
[9691] Re: flip horzitanly :S / d4rt
[9692] Re: flip horzitanly :S / no error in code.
>*Y axis
yes i allrdy got it working! :S took couple days to get it working with chatGPT! :I now i need to move object little bit down and rotate it did try many diffrent codes but nohting.
kinda fustrated now ;S
2023-02-16 09:20
[9694] Re: flip horzitanly :S / d4rt
# Rotate object around local axis
s = MQSystem
d = s.getDocument()
o = d.object[d.currentObjectIndex]
o.translation = s.newPoint(0,0,0)
o.rotation = s.newAngle(0,180,0)
m = o.rotation.getMatrix()
for f in o.face:
for j in f.index:
v = o.vertex[j]
n = m.mult3(v.getPos())
v.setPos(n)
2023-02-16 21:59
[9695] Re: flip horzitanly :S / no error in code.
>s = MQSystem
>d = s.getDocument()
thnk you so much !
here is my discord!
RoseHeart#0644
2023-02-16 22:58
[9696] Re: flip horzitanly :S / no error in code.
>s = MQSystem
>d = s.getDocument()
rotation is broken ! wierd, cube when 180 it goes nuts,
>for f in o.face:
> for j in f.index:
> v = o.vertex[j]
> v.setPos(n)
2023-02-16 23:36
[9697] Re: flip horzitanly :S / no error in code.
>>s = MQSystem
>>d = s.getDocument()
s = MQSystem
d = s.getDocument()
z = s.newPoint(0, 0, 1) # define a vector along the local Z-axis
t = o.translation + z * distance # move along the local Z-axis by a specified distance
o.translation = t # set the new position
it does not seem to work z axis :S
2023-02-17 00:32
[9698] Re: flip horzitanly :S / no error in code.
>>>s = MQSystem
>>>d = s.getDocument()
>s = MQSystem
>d = s.getDocument()
s = MQSystem
d = s.getDocument()
o.rotation = s.newAngle(0,0,6)
for f in o.face:
for j in f.index:
v = o.vertex[j]
v.setPos(n)
i just want to rotate the model just like
command panel Rotate model x axes and move down y axes
2023-02-17 01:36
[9699] Re: flip horzitanly :S / d4rt
s = MQSystem
d = s.getDocument()
for v in o.vertex:
v.setPos(n)
2023-02-17 02:55
[9700] Re: flip horzitanly :S / no error in code.
>s = MQSystem
>d = s.getDocument()
>for v in o.vertex:
it rotates model SO far i need it to rotate center of the model WORLD when i click Rotate it rotates fine in there x axisi 90. and i cant cant get working to move object down :s
same as selecting Move and move it down. :S idk :S
2023-02-17 03:23
